For a +1000$ TV, the subtitles system for the media player is not okay.
1) The subtitles delay can only go in – time. No + (later). So if the subtitles come too early, you cannot improve it. It should be possible to control by 50ms or at least 100ms instead of only half seconds.
2) The font is just bad. Not super legible, with inconsistent spacing (the space between letters is sometimes big, sometimes small), and a pretty bad design overall. Offer more fonts to choose, like other brands do.
3) The smallest size possible is still relatively big. Why not give more control options? Maybe selecting the exact size by increments of 2 points instead of 6-7 options.
4)  It should be possible to decide if subtitles have an outline or not, or shadow, just overall more control depending on personal taste and the film one watches. Just color is simply amateurish for this price.
5) Offer more options to place to font even lower on the screen. I've seen others request this.
Please LG, improve this in a firmware upgrade. Currently subtitles ruin my film experience. Thanks in advance.
    • By Jaswinder Sandhu
    • By Regis Wheeler
    • By JasonB
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By u84six
