By
atcronin
Cedric
Since my TV updated to the last WebOS firmware 05.20.08, quick access key (Long Press 1 for HDMI1, Long press 2 for HDMI2) are reset each time i shutdown the TV, and i have to set them after each reboot...
I tried to restore the factory default settings on the TV to see if there is any change, but sadly this didn't fixed my problem.
Any idea please ?
9 answers to this question
