LG C1 headphone connection
By akhil7j
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
By makem
I have a LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
By JohnS
New user on here.
I bought this new TV last week and it is honestly driving me bananas.
When I click "Home" after using an App, etc, it brings me to the WebOS interface but then automatically selects the last used device (e.g. Fire stick, LG Channels, etc) despite me not wanting it to.
Is it possible to disable this, i.e. "Home" brings me to WebOS and stays there? I'm sure its a setting etc which I'm missing.
Device is LG UQ91 43 inch 4K Smart UHD TV, pretty sure its all up to date.
Thanks in advance.
By Bob17821
I have problems with one of my WebOS TVs which looks like a speed problem, but when I do a speed check on my iPhone from just a few feet away the connection speed looks fine. Thanks, Bob
LG 65C12LA and sound output device (eARC)
- soundbar
- headphones
- (and 1 more)
- 2 answers
- 1,748 views
Using ARC sound bar and bluetooth headphones at same time C9 OLED TV
By Nigelrw,
- soundbar
- headphones
- (and 2 more)
- 3 answers
- 5,569 views
- 0 replies
- 1,535 views
- 0 replies
- 2,208 views
Eric Ramsay
I am trying to connect my LG C1 to my wired Sennheiser RF 175 speakers. My tv is also connected to a Sonos Beam soundbar via EARC. Having selected Wired headphones on the Sound out menu, the headphones come on for about 3 seconds and then both the TV and Sound out menu flick back to HDMI. I have tried using two further wired headphones and also some Bluetooth headphones but all show the same result. The only way I can get the headphones to stay on is if I take the HDMI lead out of the tv, thereby disconnecting the soundbar. I didn't have this problem with my previous Panasonic TV because as soon as I switched on the headphones they came to life together with the TV. I can't see any LG menu item that I am missing. I have also logged the issue with LG - no reply yet. Any ideas please?
