LG 49um7000pla to play files from my Synology media server
By Lorenz
By wallyricks
By Bella Lee
link hidden, please login to view. With Tunelf Spotibeat Music Converter, you can and then transfer them to LG webOS Smartwatch for playing without limits. -
By Gregor Huc
By Abhishek_02x
I am using the lg tv from 2 years and I found an amazing experience till now.
But I like request about Play box TV app. Please add this app in store section so that I could download it on my tv.
It would be helpful if you respond to my email. This app is very demanding now a days as it comes with the excitel broadband service.
- 0 replies
- 5,719 views
- 7 replies
- 16,458 views
phildunford
I use my LG 49um7000pla to play files from my Synology media server.
This works fine and until recently the TV has remembered the place I stopped, so I can pick it up again later. Recently it resets to the start of file every time I start again. Not very convenient when the LG can only fast forward at 4x.
Does anyone know how I can fix this please?
