WiFi keeps disconnecting from 55K8000PUA smart TV
Why is my WiFi disconnecting from my TV.  Sometimes it is good for several days but then keeps dropping out.  TV is 3.5 years old.
Most noticeable when using in-built DAZN sports app.
I have installed new cable modem, router.  I have installed new ethernet cables for TV, printer and and PC with Windows 10 Pro.
Help is appreciated.
Andara
I have seen countless "solutions" which do not work.  Finally concluded that the TV's wifi module was overheating after 20-25 minutes.  Set up a fan to blow a light breeze across the back and have had no disconnects since then.  My TV has no provision at all for ventilation.
    • By NickL
      Br,
      Nick
    • By agus
