The Oldest Washing Machine in the Country
By qix70
Hi, could you help me please?
My code now is 541641992
By Sqwazy
By Cash
Have LG OLED 55B36LB bought in 2023 in UK.
Trying to change area option from 3122 (EU-UK) to 4816 (AJ-India) using a service remote.
It does not update or change.
any help for guidance will appreciated.
By ebr9999
That Orange field (from SM/etzadjust) I can click for modification on my C1, but I cannot on my C2.
Any hint about how I can achieve that?
Background: my goal is enabling PVR/TS, enabled on my 65C1, but disabled on my 42C2.
I know it is risky, but copying the value of the same model with those features should achieve that, as discussed here:
By Nishanth Noble
Hi Everyone!!
I own an LG Smart TV and I am trying to create an LG account by using the option 'Accounts" under the settings. When I try to register, I show an error message " Unable to retrieve LG service country information". I am in Oman and the LG service country is selected as Oman.
Regards
Nishanth
