gigabit ethernet USB to Gigabit Ethernet adapter for LG LM6370PLA 32" TV
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
By Musica napoli live e anteprime
Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
By Caap
Good afternoon, someone can tell me which RJ45 to USB 2.0 adapter is compatible with an LG C2 WebOS 6 (LED 55" LG OLED55C2PSA 4K Ultra HD)? I can't find it. Thank you very much. Caap
By Mihai B.
Is there any way of installing an usb gigabit network adapter on a webos smart TV? The builtin wired adapter is only 100mbps (on a 2000$+ TV, shame on you LG!!!) while the wifi (N) is very poor, with the router at 1m from TV it only gets half the bandwidth of the wired network. Anyway the wired network maxes out near 100mbps but I need more bandwidth as I have 4k video content with bitrates grater than 100mbps which I cannot stream without stuttering to TV through XPLAY/PLEX.
Kind regards,
By oled55c11lb
Hello!
I would like to share my screen from my PC(Win10) to my LG TV(OLED55c11LB). Both devices are connected to the same network via Ethernet CABLE. It is not possible to connect with HDMI, devices are in diffrent rooms. When I try to find the TV on the screenshare list it's not showing up although it is visible is my network in explorer. I can easly screenshare from my phone.
I tried the customer support which resulted in nothing except reverting my TV to factory settings. Has anyone done this before? Is it even possible? I would love to be able to game with wireless mouse and keyboard on my TV.
- 2 answers
- 3,837 views
- 5 replies
- 14,474 views
- 136 answers
- 150,714 views
md127
Anyone aware a Gigabit Ethernet adapter model that might work with this TV. I already tried the Cable Matters adapter but it didn't work.
Adapter:
