WIFI/Bluetooth NG/NG ? Is there a chance to fix in software?
By Will M
By Stuart GIBSON
I have a 48" OLED (Model: OLED48A26LA). after updating to software version 13.30.61 the Sky New Live feed just displays "There was a problem with this video [timeout]". It worked perfectly before the TV software upgrade.
Ive reinstalled the Sky News app but still doesnt work. wifi etc is all ok.
Any ideas?
Stuart
By Chris Jones
My TV is driving me nuts!
I keep getting reminders for programs starting for programs I don’t watch or have never watched and 2. The tv even switches on for scheduled programs that I haven’t set.. actually I have only ever set one program reminder and that has now been deleted.
I can’t see any programs in the reminder page or anywhere in the tv programmer?
Short of resetting the tv I don’t know what else to try? And I don’t really want to do that until I know how the tv ended up like this? Plus I don’t want to have to reload and sign in to all my apps 😬
By Batman
I have a LG 43QNED756RA AEK Smart TV
If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
So I cannot Move or Edit Program Numbers or Delete
Any help and comments would be appreciated
Hale
We had a 40A power breaker overload, and shutdown. After that our 55UB8500 started without Bluetooth and WIFI.
First time I revived the WIFI/BT (and magic remote) with the TV hard reset, and waiting for a few hours unconnected. It worked almost 2 days, and WIFI died finally.
I tried ordering second-hand WIFI modules from ALiExpress junk stores two times, but every time there is NG/NG in In-Start against WIFI and BT.
Of course, I tried resetting it in various combinations.
The most confusing thing is that USB works fine, IR works fine, RJ45 works fine! So there should be all the voltages. There are no errors in power log, every time it is a power-button action, or a timeout at the input when PC and Nintendo are shut down.
So I have a suspicion that something is bad in the software/deep configuration? How do you think? Is there a way to restore, or a simple way to debug without the service jig?
My original unit is configured for Japan with WIFI made in Philipines (if I remember correctly, I need to dig it out from the junk storage box). The junk modules I ordered are Chinese. Made in Philipines and China, I do not know, do they have a regional lock or free to swap.
