Files downloading is not supported
By Evelynn
I am trying to access Livenettv through my LG smart TV however I keep getting the downloading not supported when wanting to download V4.7 apk file. Please can you advise?
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
By mahdi alborzi
I need to update this TV
Model : 55SJ850V-TA
Serial number : 707CGKWMJ215
ESN : LGTV20171=11001816919
VSN : 1F580793
Widevine: LGTV17CLGE002389488
By mahdialborzi
از درگاه وای فای بروزرسانی نمیشود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
لطفا کمکم کن ید
By dolbnya
Jitendra
Why is not supported the files downloading lg uhd tv please help me
