downgrade LG tv 55UH6030-UC
By SIMON
LGDTVUPDATER
1. Download LgDTVUpDater [
link hidden, please login to view | ] Updated 19 OCT 2015
2. Unrar and put LgDTVUpDater folder in C:\
3. Open C:\LgDTVUpDater\dns\AcrylicHosts.txt
4. Change 192.168.0.11 with your
5. Save and exit
6. Go back to C:\LgDTVUpDater folder
7. Run startDNS.bat and don´t close it
8. Run startHTTP.bat and don´t close it
9. Go to TV Menu > Network Settings > Ethernet/WiFi > Edit > Uncheck Set Automatically > Change DNS IP to your local IP address > Connect
10. Go to General > About This TV > Check For Updates
11. Accept downgrade to the first firmware TV
12. Restart TV
13. Back to TV Menu > Network Settings > Ethernet/WiFi > Edit > Check Set Automatically
14. Go to General > About This TV > Check For Updates and follow TV instructions OR download available Software_File dedicated for your TV, unrar and put *.epk file in LG_DTV folder at USB stick
15. Mount USB stick to USB port at your TV then accept upgrade when message prompt on the screen
16. Restart TV and follow TV instructions
For best performances go to TV Menu > General > Reset to Initial Settings
Voila!
NSU EMU BY SMX
If your attempt to downgrade your TV with LgDTVUpDater for some reason was not successful, you can try to use tool prepared by SMX.
Everything you need - NSU Emu by SMX and how to use it - you can found .
By Alexander Baumann
Hello everyone,
my TV did an upgrade from 06.10.01 to 06.10.30. Is there a way to get the old firmware file and make a downgrade? If so, where can I find the file?
Alex
By ReproDev
link hidden, please login to view This guide should help you downgrade the software on your LG TV so you can get root if you've updated to 3.30.10 like I did.
I've tried to include as much information as I can and there are 3 methods to choose from on the GitHub
This has been tested and confirmed to downgrade on an LG 43 Inch TV 2021 Model - LG-43UP75006LF from Software Version 3.30.10 to 3.21.30 but should work on other LG TV models too with the relevant firmware for that TV.
Hope this helps and let me know if you've tried it
By TheMasiaox
IS there a way to downgrade the last browser? It just broke everything, there is no real full screen, some websites dont show correctly, it has issues trying to reproduce 4k videos... it is just bad
My TV is a 49UM7100PSA I was very happy with it until this upgrade and I dont want to buy a roku or fire stick whatever to solve it.
By Zecco77
Ciao, possiedo un tv lg 55uh650v era impostato su posizione Russia e dopo all'aggiornamento del firmware versione 05.30.45 non riesco più ad usare le app in quanto non riesco a accettare i termini contrattuali. Ho provato a cambiare il DNS e a collegarmi tramite cellulare ma non ho ottenuto nessun risultato. Ho provato più volte ad eseguire il reset di fabbrica ma nessun risultato. Inoltre ho notato che la versione del mio firmware non è presente sul sito LG Italia mi chiedevo se fosse possibile tornare ad un versione firmware inferiore, potresti aiutarmi?
Hello, I own a TV lg 55uh650v was set to Russia position and after the firmware update version 05.30.45 I can not use the app anymore because I can not accept the terms of the contract. I tried to change the DNS and connect via mobile but I did not get any results. I have tried several times to perform a factory reset but no results. Also I noticed that the version of my firmware is not on the site LG Italy I wondered if it was possible to return to a lower firmware version, could you help me?
Taraba139
Anybody have any older version software of 05.65.03 i need to downgrade my LG tv 55UH6030-UC.Thank you!
