By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
me
When I first got my tv I opened YouTube and let the tv login as lg……. it has always show up as LG and I’ve always used that. Now that has been lost and YouTube wants me to login. Was there a default email the tv used on first sign on, can I get it back? Maybe lg(model number)@something.com?
