3 answers to this question
Hi Ganesh,
Since you have mentioned, only Aha app is getting stuck, I guess your internet speed is good as other streaming app are fine. So, it could be problem with the Aha app, may be a fresh installation can help you, here are the steps you can try
  • Uninstall the Aha app in your LG Smart TV.
  • Log-in to your Aha account either with mobile app or web browser (not in the TV).
  • Navigate to
     and remove clear all the instance of lgwebostv and any other instance that you think are not necessary.
  • Re-install the app in you LG Smart TV.
  • Link the account and hope it resolves the issue.
Fallowing these steps helped me resolve another issue for me, previously.
    • By RJ Fischer
    • By Regis Wheeler
    • By JasonB
    • By AMK
      Tv model 55UJ630V-TA
      Sw version 06.10.50
    • By jcol5786
