By Horniak
By CJ Catalano
By JRay
By P.T.
I have a LG G3 Oled Tv 65 inch. I want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of a USB HDD that will work on my TV .
Peter
LG brings Apple TV App, Apple Music, AirPlay and HomeKit With webOS Hub
By News Reporter,
- apple tv
- apple music
- (and 1 more)
- 1 reply
- 2,513 views
- 2 replies
- 3,617 views
- 2 replies
- 8,908 views
- 1 answer
- 6,701 views
SimonW
WebOS 05.20.15
DNS over TLS active on router (Cloudfare), all apps (like Netflix, Prime Video & HBO Max etc) are working fine, but the Apple TV app times out (no network)
Removed the app, installed it again, but still not network. Turned DNS over TLS off, Apple TV works fine.
According to Apple it's a LG (WebOS) issue, the only requirements, they say, are "active internet connection" and "no VPN".
Also tested with Apple TV on a Fire TV Stick (on same network) and there it's working fine wiht DoT. Unfortunately Fire Stick is not 4K, so app on TV is preferred.
Look to me issue is with the Apple TV app itselfs, but Apple says it's LG.
Anyone got some suggestions?
