Can I get this player that is on my LG TV for my PC?
Some apps are created especially for the device or manufacturer but there are exceptions. It would help if you specify which Player you want to use. On my TV I use an IPTV player but on my PC I use others. The ones from the LG store are mostly available for both PC and mobile devices, for PC there is a greater variety so it shouldn't be difficult for you to find something suitable. You can search by the name of the app in question or look for similar ones.
    • By wallyricks
    • By Nishant singh
      Hi Team
    • By Matt Moran
      Matt
    • By Kemal Sözüner
      I recently bought a LG TV with WebOS version 8.1 and have a frustrating issue.
      I have a usb disk with all my family photos & videos archive in it.
      We love to browse through the pictures and videos on big screen.
      But current LG TV media player displays either pictures or videos. I want to see them in the order they were captured.
      It would be great to enable this feature when "Photos & Videos" filter is selected.
    • Solution For That Pollution
    • By Kemal Sözüner
      Is there a way or another app to view photos & videos at the same time? (slideshow)
