Browser and Youtube app doesn't start
By Andreas Boyatzoglou
Model: OLED55BX3LB
Viewing videos from
link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
barnanag
Hi folks,
I have a 50NANO863PA television and facing the following problem: when trying to start either Youtube or browser app the TV immediately switches to HDMI output and the app wouldn't start at all. Please watch the video I've recorded:
I tried restoring to factory settings, and the apps started a few times, but after that the same issue arise. The OS is updated to latest version. Did you witness/hear about a similar issue before?
Your input is pretty much appreciated.
