Weird Youtube app malfunction
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
PB-
Hello there,
i am having a very weird and annoying problem with the youtube App.
I am running it with my CX8 55inch Oled Tv updated to firmware 4.5 and since few hours the app refuses to properly functions. It open and it shows videos but it does not show the left menú and therefore all functionalities beside homepage carousel of video.
On top of it, when running a longer video it randomsly shows the no network error and ask to "refresh", then it moving down with the arrow you can restart the video roughly 10-15s before you had the crash.
I tried to close the app, remove and reinstall the app, hard reset the TV.
Nothing worked.
Only thing left, that is much annoying, is to reset to factory conditions.
Does somebody have any solutions?
Thank you,
picture:
