Chinese Kanji in YouTube app ?!?
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
schumichamp
I'm experiencing something new here !?!
I have an LG OLED 55 C7V.
I did NOT change my location or any parameters in the system of my TV but now when i launch YouTube App, i have some chinese Kanji in my YouTube vertical left menu.
My OS is up to date. My YouTube app is up to date.
What is going WRONG ?
Thanx for your answer
4 answers to this question
