WiFi turning off
By agus
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Guest
Things that I've tried:
factory resetting the tv leaving the tv unplugged to delete cache using google's DNS on the TV using a wired connection Having said so, I am so lost that I would be happy to try anything again.
By loafty
Tv connects to wifi and can stay connected for couple of days then I will switch tv on and internet (wifi) will be disconnected so go to connect up again and tv can't find any networks so turn off and unplug from power wait 5 to 10 minutes then plug all back in go to wifi settings might be lucky to find my network select and enter password and works again. Only thing is I got a different modem from internet provider and they have told me that the modem is working fine but I have never had an issue like this with tv before. Tv states wifi is turned off but I can't find anywhere that I can turn wifi on in the tv, does anyone know ?? Tried calling LG didn't get much help at all, I am 71 years old and just want my tv working the way it should so hope someone can help. Thanks
Ginger 1969
I have 3 different lg tv’s and am getting the same problem on all three. I have them linked to echo dots which works great till you ask it to turn off the tv. Once the tv is turned off, the Wi-Fi signal is lost and therefore you can’t ask echo to turn it back on. What you have to do is, turn the tv back on using the remote, then go in to settings and reconnect the Wi-Fi. I have searched the forum to see if others have had this problem and can’t find anything, hence posting this thread.
I have searched the net and watched dozens of vids on utube and tried every suggestion offered, except taking the back off the tv and straightening the cables.
I’ve tried: date and time, changing countries and back + turning off auto location, resetting tv, resetting hub, modem and mesh, turned off quick start, turned off simplink, turned tv off, unplugged tv and maybe a couple more I’ve forgotten, all to no avail.
Any ideas????
