Factory Reset, Remote Won't Work, Stuck on Press the OK button(wheel) on your remote (55NANO81ANA)
23 answers to this question
Having the same issue with my OLED77A1PUA, did you ever figure this out?
Hello
Exactly the same issue on 49SM8600 and did same operations but still stuck w/o access to apps menu, settings menu, ....
Did you find a workaround or a fix ?
I wonder if this operation could help to reset bluetooth module :
On 1/2/2023 at 12:11 PM, lacal said:
Hello
No, I still have no work around. This is killing me, the TV is just $2,000 brick and it's impossible to return now.... I can not believe you can not get the TV to accept an input without going through the "Press the okay button" screen. I've tried 5+ remotes and many many hard resets, I think the IR receiver at the bottom is broken (I have no red light with the TV on or off). I'm using this as a display so I don't need the remote to work.... If someone has a work around to get past the "press the okay button" screen and get the TV to accept an input that would be very helpful.
If you connect an USB mouse you will be able to click on the OK button. Configure wifi just after clicking to have a chance then to use an app on your smartphone as a remote. I didn't and now i just have LG chanles w/o any other menu and no possibility to reset again. Magic remote and bluetooth handling is a big shit on LG TV.
I am currently stuck on this screen as well. Brand new TV. LG has me repeating the same moronic steps. I think the sensor has malfunctioned on the TV. An expensive situation.
So I try the workaround for wifi issue but it has no effect on my LG situation.
Still same situation, no standard remote working. I just manage to use my smartphone with wifi.
All,
I was at an airbnb and the LG TV had the message to hit the OK Wheel button.  Didn't work.  All the remote would do was turn on and off the TV.  Also the bottom button would only do the same.  Basically stuck in set up mode.
I did plug a Corded Mouse into it and it allowed me to hit the OK Wheel Button.  It was by clicking down on the scroll wheel on the mouse.  That only got me to the next step and I was stuck again as I couldn't go up and down.
Solution (for me) is I plugged a wireless keyboard (I'm sure wired would work) and then used the up and down keys and the enter button to finish running through the setup.
I hope this helps.  I don't have an account on this site.
My LG Nano75 50" 4K Ultra HD LED Smart TV got stuck on the Quick Access screen right after the last update. I spent several fruitless hours on forums and trying all the fixes to no avail. In a fit of pique, I mashed all the keys together and the screen is now cleared and the tv is working again.
I figured it out! Hold power button at bottom of tv (may need another person to assist) while pressing wheel. It will then pair remote and ask if you want to adjust language settings
Yes hold the power button at tv and remote wheel at same time
It did not work on my oled65c2 tv. I have replaced all boards twice. Is there normally a standby or power light close to switch?
TV comes on immediately upon plugging in with instructions to press wheel on remote.
Same issue here and I just figured it out myself, connect it to a keyboard, plug it up and it works just did it this morning I was stuck on the same screen, tried 30 different remotes and a mouse and nothing happened until I plugged the keyboard and it worked. Try it!
I found mine to be sort of self inflicted. It seems lg decided to use flip up disconnect for all ribbon connectors except the one that goes to power switch/ IR. It is opposite so it was essentially disconnected. After I found that, everything worked. Thanks for response.
never again with LG! lol no problem.
Has anyone been in the tv?  If this tv is like mine (oled65c2) then it is not getting the 3.5v to the power switch/IR module
According to my experience, you must first
<a href="https://rokuinsider.com/clear-cache-on-roku/">clear cache on Roku TV with or without remote</a>
  and then do a factory reset, if possible reboot your Roku device and see how it goes.
Ok guys i had the same problem and i got the solution finally after trying everything single thing, USE AN OLD LG TV REMOTE!!!!
It will press ok button then you can register your magic remote after resetting your tv it worked perfectly!!!
Same issue with my 65” nanoUPA LG
Won’t receive any remote signal so I factory reset it using my phone. Now stuck on the point remote and click “ok” button. But no remotes will work! Bought 3 new ones online including one from LG. HELP.
The USB mouse trick works
Found a solution to this today...... use the remote to switch on the TV (double click the on/off button on remote).  TV will then recieve input from the remote and allow setup to continue.  It's very slow/unresponsive initially but after a couple of minutes a box appeared on screen saying that the remote had connected and it worked perfectly thereafter.
I had been using the on/off button on the TV which didn't alloow remote to connect.
What worked form me was to plug in a usb keyboard that has a touch pad (logitech k400 plus ) then i setup app "Remote control for Lg " had to turn on the TV with button in front but every work great after that and was able to turn TV off .
