APPS CLOSING WHILE IN USE.
I currently own a OLED65C1PUB 2021 Model purchased 1 month ago and it has started having some issues. I don't have cable or satellite TV. I stream everything and recently while using apps on the TV they will just close and the TV switches to my HDMI 1 input that has a chromecast plugged into it. Sometimes it will go straight to the Screensaver instead. This happens quite often and is very annoying. Length of time in thr apps doesn't seem to matter, sometimes it will happen after 20 minutes of watching and sometimes after 30 seconds. Completely random. Has anyone else had anything like this happen to them. And if so any luck finding out what is causing it?
Sent from my SM-G986U using Tapatalk
    • By Batman
    • By Pranay Mokida
    • By MNHL
    • By Tobin
      Tobin
    • By Luka Pantsulaia
