55nano80 slow ram
By Mandx
By Peter_T
By NickL
Br,
Nick
By Den C
By Saga
Any Ideas?
The web browser is really slow. It has Always been slow but has gotten slower and slower. Resetting the TV did not help. When selecting a box for Writing it may take 15 s to get the selected letter to show in the box. Typing the name of for example a TV show takes minutes. No errormessages are ever shown but it seems like a memory issue. but then again I hoped it would get better as I did the reset. Any ideas?
Lazo Salim
Hi guys
I have a problem with my LG 55NANO80 , After i update tv ,
I feel slow system and also lagging sometimes when i open browser
