Standby Mode for Wi-Fi command?
I've got my ThinQ and Google Home apps and Google Home speakers set up to turn off my LG C1.  But they won't turn it on, I guess because the TV isn't listening for commands when off.
I expected that enabling these
Settings|General|Devices|TV Management|Quick Start+
Settings|General|Devices|External Devices|TV On With Mobile|Turn on via Wi-Fi
would do it, but it did not.
OMG I just discovered that Alexa turns on the TV...and I never even had to open let alone set it up in the Alexa app!
    • By Justin Bester
    • By NickL
      Br,
      Nick
    • By agus
    • By atcronin
    • By Pranay Mokida
