App Review: Notes HD
The built-in Memos app for webOS
. We all know it. With a big 9.7-inch screen like that on the TouchPad, its even more unforgivable how basic it is and how little its been updated. If there's one good thing about the pitifulness of the TouchPad Memos app, it's that it has opened the door for several third-party developers to built the better notepad. One such developer is Inglorious Apps, who created the aptly titled and well-featured .
For the asking price of $1.99, Notes HD drags memos on webOS up to modern standards. Well, really it brings back a lot of the features from the Palm OS Memos app, including titles, password protection, and categories (gasp).
a2t.imglr1oej1066o
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
    • By Alex
      Thanks to @Peter Alexander and @SSM we have confirmation of webOS 4.0 compatibility within the release notes and information listed for their respective apps in the below topic.
      We've confirmed the iOS version changes:
      We've also confirmed Android:
      Both version updated were added this week. We are waiting for an official webOS 4.0 press release from LG and additional information on what models are supported.
        Q10 in 90 minutes
