Unable to see bigg Boss error showing as PI 6006 NAS
Iam unable to see bigg Boss in Hotstar appsince morning error showing as "PI 6006 NAS".
Iam using LG webOS TV UM7780PTA.
Please rectify it as soon as possible.
    • By Hasan Ghasabi-Oskoei
      Can you help?
    • By keshav iyer
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By alfie
