By hollean
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
- 0 replies
- 4,917 views
- 8,503 views
Dave S
I have an LG OLED and I want to change the volume of my Bluetooth headphones independently of the speaker volume. I am hard of hearing and I want to listen to the TV a bit louder than the speaker. Presently the Tv Volume controls both. Thanks
