PreCentral: Deleted a default TouchPad app? Restore it with Internalz Pro
Sometimes, for reasons we've yet to determine, the built-in first-party apps can disappear off an HP TouchPad. It's rare, but it happens, and for the average user it's annoying, frustrating, and confusing to have a basic app like the App Catalog or Calendar just up and disappear. Thankfully, HP has made it relatively easy to restore these apps, and you can do it all on your TouchPad, though some homebrew magic is required.
First things first, you'll need the excellent homebrew file browser
installed on your TouchPad. Our will give you a step-by-step of how to install Internalz (or any other homebrew app, for that matter).
a2t.imgpH8PRjxi5Dg
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By woof
      I have a couple of LG OLEDs in shared spaces, with external speakers, one via optical and the other via analog jack (confusingly named headphones). Whenever bluetooth headphones are used and then disconnected, the TV reverts to "internal" terrible audio. For non-technical people this is permanent. Do I have to train everyone to select the device from the long list or can I set a default?
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By starwoodtech
    • By starwoodtech
      I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
      Does anyone know what it would take to set this?
