auto dimming on webOS YouTube is extremely annoying.
By Venkata
Hello Team,
By Roy Brown
By Khelben Arunsun
By magicschooldropout9
By Lee Magee
leimberger
While watching YouTube on my WebOS TV, I very frequently pause the picture and I do not like the picture dimming the second i hit pause. It makes an extremely unpleasant experience when the remote requires 6 actions to go from 'pause' to 'play'.
Step 1) push 'pause' (screen goes dim)
Step 2) 'up arrow' (to get rid of dimming)
Step 3) 'up arrow' a second time (to finish getting rid of dimming)
Step 4) push 'play' (screen goes dim)
Steps 5 +6) repeat steps 2+3 (screen is now bright and playing)
6 steps? 2 steps is the ONLY logical number. 1) pause and 2) play (actually just pause for both pausing and play but we'll leave that for now) 6 steps makes for a VERY unpleasant viewing experience.
Yes I am aware the screen will return after about 3 seconds. (unpleasant/frustrating)
Yes I am aware that I can use the 180 degree arrow key to reduce the number of steps to only 4. There are 2 problems with this method. 1) Its still 2 steps too many. 2) If i wait a split second too long, the screen will return to bright screen at the same moment I push the button and now that 180 degree arrow button is programmed to return you to the main menu. This makes it even more aggravating because I now have to go into the history menu to restart the video.
Can someone please tell me how to eliminate the auto dimming? If its not possible, can the webOS programmers just reprogram the system to stop doing this. Yes, its a first world problem, but when you hit 'pause' as much as i do, honestly want to return the TV. I can't take how poorly it was designed. It makes no sense. thank you for your help.
