UK6400PLF - no longer able to automatically switch to HDMI channel after turning on PS5
By OliverRC
By hollean
By JamesH
By Kane Murphy
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
Finjo
Hi, whenever I turned on my PS5 in the past on my TV I would get a prompt in the bottom middle to press a button to automatically go to the HDMI channel, now I still get a notification in the top right saying “HDMI 1 is available” but it doesn’t seem clickable.
Has this been caused by a software update? I did also set up a sound bar in the HDMI ARC port recently and wondering if it could have anything to do with that?
