Almost a year since I have my LG C1 still no Google Assistant or Smart home assistant support for Philippines. It's included in the website and marketing materials, but LG left me hanging until now.
Definitely a non-smart home friendly TV.
  • 1 year later...
      Company Enhances Smart Home Connectivity With Open API
      SEOUL, Dec. 17, 2024 — LG Electronics (LG) has fully opened the Application Programming Interface (API) of its smart home platform, LG ThinQ, enabling developers to easily create smart spaces with LG appliances.
      Recently, LG launched the LG Smart Solution API Developer website (
      link hidden, please login to view) to officially open up the LG ThinQ API. An API acts as a digital connector that allows different software to exchange functions seamlessly. Developers can utilize the open API to integrate various features from LG AI appliances into their programs or systems, enhancing their services. The LG ThinQ API is divided into two categories: the ThinQ API for individual users and the ThinQ Business API for corporate partners. The ThinQ API allows for remote control of LG devices installed in homes or buildings and facilitates integration with various platforms.
      For individual users, the ThinQ API supports the control and monitoring of AI appliances registered in the LG ThinQ app from various smart home platforms. By utilizing the ThinQ API, anyone can easily create a customized smart home that fits their lifestyle. For example, users of the global smart home platform Home Assistant can now connect and control 26 types of LG AI appliances, including refrigerators and washing machines, within their existing smart home environment. Home Assistant is a community-based open platform with about one million users worldwide who collaboratively develop various smart home functions such as device automation and feature expansion.
      For enterprises, the ThinQ Business API supports partners operating office or residential buildings in integrating and managing various LG products, from appliances to commercial equipment like HVAC and signage, with their existing apps. For instance, large residential buildings can integrate LG appliances with their existing management apps for more convenient use. Residents can reserve the use of LG washers and dryers in common areas through the building management app, or administrators can detect abnormal conditions in the building using LG’s temperature and humidity sensors and quickly respond to issues through alert functions.
      Meanwhile, LG has accelerated the integration of external products and services into the LG ThinQ platform by acquiring the smart home platform company Athom, known for its extensive IoT device connectivity. Athom’s smart home hub Homey currently connects over 50,000 types of appliances and IoT devices, and the Athom app store features around 1,000 apps that connect and control products and services from global brands like Philips and Aqara. LG plans to integrate Athom’s extensive open ecosystem and IoT device connectivity into the AI home hub LG ThinQ On, aiming to realize an AI home where generative AI better understands customers and provides optimal space solutions.
      “With the official launch of ThinQ AI, we aim to deepen engagement with open-source community smart home power users in the open-source community and broaden our collaboration with B2B partners. This initiative will bolster our efforts to create smart home ecosystems powered by LG appliances, enhancing customer experiences across multiple touchpoints,” said Kim Kun-woo, vice president of LG’s Home Appliance Solution Company.
      * The main image is demonstrating potential use of the LG ThinQ API. Actual use may vary.
    • By Cody LUEN
      Hi!
      Version: 23.20.36
    • By Alex
      Samsung has made fridges with touchscreens before. LG has made fridges with doors that turn transparent to show you the inside. This year at CES 2018, those two ideas are finally merging into one with LG’s new InstaView ThinQ smart refrigerator, which features a 29-inch touchscreen that becomes transparent if users knock on it twice.
      LG actually tried this two years ago, with a version called the Smart InstaView Door-in-Door that ran a full version of Windows 10, but it’s not clear that the company ever shipped the Windows version.
      Unfortunately, the only image that LG has shared showing the fridge is a low-resolution shot on its YouTube page banner, but it seems that you’ll be able to still use the screen while it’s translucent, allowing you to tag food directly in a vaguely augmented reality-esque move.
      Source:
    • By Miguel Gonzalez
      I am lifetime LG CUSTOMER.
      I have a fridge, air conditioned etc. all with THINQ can be accessed remotely (WAN ACCESS)
      Some years ago I purchased 65UM7100PLA but this device is accesible only in LAN/WLAN via  THINQ
      I though this is because old WEBOS version, but I have purchased a new 32LQ63006A with WEBOS22 and I am not able to acces the TV via WAN. It,s the same. THINQ works only in LAN, at home
      I question if there is any way to remotely (WAN) access to my TV,s???
      This can be for security reasons (turn on /off away home etc.
      If  fridge, air conditioned can be accesible by WAN whyy tv not????
    • By dzoole
      Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
