file not supported problems
By Jonatan de la Torre Gómez
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
By Nick Payne
By LG tv fan
Recently live channels stopped working with an error every 2-3 seconds.
Older media is still playing.
Now I noticed that new media like today's news aren't playing either. Same error.
News from Friday 3rd may still work.
Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
By dolbnya
Berb
good morning forum,ihave been tryig to download 3rd party apks onto my LG Smart Tv but all i get is file not supported ???????
Link to comment
Share on other sites
