Google assistant doesnt work well with LG tv
By CJ Catalano
By JRay
By P.T.
I have a LG G3 Oled Tv 65 inch. I want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of a USB HDD that will work on my TV .
Peter
By Calvinder
Any suggestions
Nathan Azzi
hello,
Got a new 86nano75SQA
google assistance BUILT in works fine - and if i ask it to play a video it does.
But external google assistance on my google devices, only turns the TV on and off, and opens apps..
I cant for instance say "Play big bang theory on LG TV"
Or it says "I also need to know which device to use. try saying that again, and include the device's name"
Can anyone do this? is it it expected it works? works fine with the built in assistant, but not external ones
