PreCentral: Pop!Later is an Read It Later app that lives inside a notification
By williamsats
Hi everyone!!!
Lately I have a problem with my 40UH630V (OS Ver. 05.70.30). It takes too long for a hard drive or a USB stick to get it ready to play video files. That means that I have to plug in my hard drive or USB stick and wait for at least 4-5 minutes before I can play the video files, no matter what type/format they are. Sometimes I have to unplug and re-plug my drive so to read it.
Here I must point that both USB ports are clean with no dust or any corrosion, USB cables are new and fully functional and all hard drives and USB sticks are working perfectly on my 32LQ63806LC.
Also in some cases i get a message on TV for a format compatibility but I don't think this is the case, since if I wait 4-5 minutes (sometimes a bit more) then it reads them normally.
Any ideas?
By philotas
I followed these steps to prepare my LG TV and it all worked fine:
However I cannot push IPK to tv or just list stuff:
I am getting this error when calling:
ares-device-info --device tv2 outputs:
ares-device-info ERR! [syscall failure]: read ENOTCONN Any ideas?
I can ping the TV just fine and getting the key from the TV also worked but connection fail...
I am using macOS 12.16 and the TV is using webOS 4.9...
I also tried different node versions (v8.17.0 and v17.3.0)
Any ideas?
By infiniter
LG support is crap. No response at all or pre-made response textes only after weeks. Support is important, because we actually pay for it by buying the products. Since the TV is depending on software you provide and if this software has bugs, they must be removed, because this is part of warranty.
I posted a bug thread over at the developer forum, but no one reacted. Actually, I expected something like that an LG official reads it, puts it on a bug tracking list and comments "we are on it". That's how other companies do it.
So, where can we find a place to post our bugs so that they find their way to the developers?
By Oussama ZAQOURI
I want to develop an application for lg webos, but i found a problem when i want to read a video, and i want use a default webos player.
Are you have an idea about default lg webos player ? and how i use it ?
Thanks.
