When MX player, jio cinema will be added.
MX player and jio cinema are commonly used Android apps which offers many free to watch movies. It would be great if that two added in the lg store. Hope it'll be added soon
    • By Jack1151
    • By wallyricks
    • By MNHL
    • By GVK TEJA
      Please add Jio cinema to WebOS store. I bought it LG TV to watch world cup but i can't. I'm so regret.
      TV model: 43LJ554T
      OS: WEBOS
      Version: 6.10.35
    • By kp bose
      Please take steps to include Airtel Xtream Play app in WebOS Content Store!
      In India everyone is using Airtel network and Xtream Play as a bundle recharge offer with it!
      LG TV is very good and technically advanced! For this mere reason of not having Airtel Xtream Play App, We Customers, need to switch over to other brands!
      So, it is mandatory and timely, for LG to make Xtream Play available in WebOS TV, otherwise you have to loose your trusted Customers like us!
         Please think twice and Consider!!!
