Sony LIV and voot app not supported
By Evelynn
I am trying to access Livenettv through my LG smart TV however I keep getting the downloading not supported when wanting to download V4.7 apk file. Please can you advise?
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
By dolbnya
By tezz7624
How do you get these Sony TV channels?
Your Samsung and LG TVs get 8 blockbuster new channels this month and all for free
By odesanmi kolade
I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
Shivaraman Balu
Below are the details of my model and OS information. With this version, there is no support for Sony LIV and voot app. It will be beneficial if such apps are also provided.
Model
32LJ616D-TA
Programmes
Device Name
[LG] webOS TV LJ616D
webOS TV Version
3.9.0-63004 (dreadlocks2-dudhwa)
