I bought a LG oled tv from Muscat last year and brought it home (india). But I cannot change the country to India. The location change has only access to GCC countries. Upon researching through the internet, i found out that if i had service remote I can change my country to India. My model number is 55EG9A7V-TA. I would like to know if whether the service remote in question MKJ39170828 will work with my OLED tv if bought ?
Thanks.
    • By qix70
      Hi, could you help me please?
      My code now is 541641992
    • By Sqwazy
    • By Luka Pantsulaia
    • By 43UR81006LJ
