Lg smart to mode 49UT761H0TA
2 Gaming Portal is available on LG screens running webOS23 and beyond in Austria, Belgium, Brazil, Canada, Chile, Denmark, France, Germany, Italy, Ireland, Mexico, Netherlands, Poland, Spain, Sweden, Switzerland, Turkiye, UK and USA and will expand to more markets and down to LG screens running webOS 6.0 by the second quarter.
By Justin Bester
By atcronin
Kiran btw
Does my smart tv support webos my smart tv is a LG 49UT761H0TA. I am trying to find content store but I can’t find it plus for the network connection I have to hold setting for 7 second and than type 1105 to go to network setting as it isn’t in the normal setting option. Anyone help answer my two question.
