This tip is only for webOS phones
Bing Maps options for phonesWhen webOS 3.0 and the TouchPad were released, Bing Maps was the default mapping application, replacing the Google Maps app that was installed on al webOS phones. Shortly after, those webOS phones were then updated to also replace Google Maps with Bing Maps, bringing almost all of the same functionality of the larger tablet-based version. One similar feature is the ability to
, including the standard street map, satellite view and the "Bird's Eye" views that provide an angled viewing of a map. Unfortunately, unlike the TouchPad version, you can not rotate the angle of the Bird’s Eye view.
To change you desired view type, tap on the BingMapOptions.png  icon on the top-right of the app to open the “OPTIONS” screen and use the bottom dropdown to select your “VIEW”. This will then take you back to the map and reload it as selected
a2t.imgXB1ZlO30tl4
