How to close apps in the background
By magicschooldropout9
By Pranay Mokida
By MNHL
By Tobin
Tobin
By Luka Pantsulaia
I bought LG smart tv. for some reason region selected was Africa and could only choose from african countries and had very little available apps in content store. I live in Georgia, so figured that changing region to EU would help so changed it to 3122 and selected service country UK because Georgia was not in the list. after that every app says that it is not available in current country. I have default region code saved so I guess could go back but wondering if any one can help me to get it working in EU. or if anyone have region code in which Georgia is available it will be helpful as well.
willjim
I have recently purchased a qned 99 and I can’t see how to close apps running in the back ground like I was able to do with other lg TVs I have.
The tv is running the latest version webos and obviously tried YouTube for the answer which only seems to say holding down the home button but all this seems to do is open the last app I was using.
any ideas gratefully received.
