How to add a new satellite which is not on the default list of LG webOS TV ?
I have a LG webOS TVUM7050PLF which is being used with a satellite dish in my vacation home. I am trying to add a new satellite, which is not included in the embedded list of 30+ satellites of this TV.
Can anybody help me on how to add a new satellite, which is not included in the TV's existing list.
    • By OhmorrowSouthWales
    • By Michael Hirons
    • By Tony Levy
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Damian1
      After searching high & low, & also on the difficult to navigate LG website, I can't find which magic remote is compatible for my TV.
      The model.of my LG TV is - 32LQ630B6LA
      Can anybody assist, please?
      Many thanks.
