Casting Error Code 201
Apologies for what might be a newbie question.  I have a 55" Nanocell 80 series TV.  I've used it for, among other things, casting FloSports from my iPhone.    This always worked well and was much more stable than Roku, which kept throwing me out of the app.  I go into the FloSports app on my phone, it prompts me for the casting output, I choose [LG] webOS TV NANO80UPA.  Until now, it has always worked.
Last night, out of nowhere, I got an Error Code -201.  I looked it up:  Unable to Load, Server Certificate has expired or is not yet valid as the set time on TV is different from the current time.  Please check time settings.  I checked.  Time settings are correct.  It was suggested that my Internet speed may be lacking, but other apps like YouTube work just fine.  Another tip was to ensure I had the most current software patch.  Apparently, I do (03.33.11.)  Googling it suggests that this is a YouTube error but, again, YouTube is OK.  AirPlay is not.
Any ideas?  Thanks in advance!
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By 43UR81006LJ
    • By Ramya Shyam
