Software version 03.00.06 on HU715QW
I recently purchased a HU715QW LG Projector which came with software version 03.00.06, does this mean I am on WebOS 3.0, is there a way for me to get to 6.02 which seems to be the latest version of WebOS? Thanks for your help.
    • By OliverRC
    • By NaveenKumar
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
    • By Ali Zia
