  • 2 years later...
To enable Developer Mode on an LG Hotel TV (model 50US660H), follow these steps:
  1. Access the TV's settings: Use the remote control to go to the "Settings" menu. Find the "General" or "Hotel Mode" section.
  2. Enable Developer Mode: Look for the option to activate "Developer Mode." If it’s not visible, you may need a special service remote or access code from the hotel or TV provider.
  3. Connect to PC: Once Developer Mode is active, install the LG Developer Mode app on your computer. Connect the TV and PC through the same Wi-Fi network or with an Ethernet cable to start developing.
Make sure to check LG’s support for specific guidance based on your model.
    • By atcronin
    • By Pranay Mokida
    • By Cody94549
    • By Rayden79
      I'm having this problem with LG Oled 65c16LA with WebOs Version 03.40.85
      When I turn off the TV, it goes into standby mode.
      After 2 minutes the red standby LED turns off and it is no longer possible to turn the TV back on with the remote or with the power on button.
      It is then necessary to unplug the power supply, wait a few minutes and reconnect it.
      So the TV goes back to standby and you can turn it on again. In use everything works.
      Is it a software problem? How can I solve it?
      Thank you
    • By Seppel
      i am in the process of purchasing several LG digital signage displays and need some more information before i place
      my order.
      I need a function like kiosk mode to start a website in full screen mode on device startup.
      The device would be a LG 43UH5N-E installed is webOS.
      Is this posswible with the onboard functionallity of webOS or do i need a 3rd Party App ore something?
      There is no need for a pagerefresh or such things, only display of es simple Website.
      thx for help me out.
