Multiview with two hdmi inputs
By OliverRC
By DW1
By hollean
By Kane Murphy
By pingber
All of a sudden, the row of inputs showed up at the bottom of the home screen on my C1. I’ve tried every setting but can’t seem to get rid of them. I used to just call them up as needed (input button on remote) but now they’re there permanently. Any ideas?
Brendanchatt
Hello all,
From what I can tell, this may not be supported anymore. I am on webOS TV Version 7.1.0-68 (mullet-maria).
I just purchased an OLED 42 inch C2. When I select Multiview, the two hdmi ports are not an available combination.
I have turned of CEC (now SIMPLINK) for both HDMI inputs as I read in a post from 2018.
Thank you,
Brendan
