Is WebOs available for LG 42LA620S-ZA? If not when is it going to be available?
By tarakdave
By AtWitsEnd696
By SHawk
By Bella Lee
link hidden, please login to view. With Tunelf Spotibeat Music Converter, you can and then transfer them to LG webOS Smartwatch for playing without limits. -
By Gabriel Śmiech
Matei Fărcaș
Any word if LG will update their 2013 range to webos, my 42LA620S-ZA is screaming out for webos, gets me mad my tv seems obsolete, give your customers the choice to upgrade, hell I wouldn't mind paying a fee for the update to webos but something tells me my tv is stuck in limbo.
