LG 49UJ634V WiFi Issue
By RJ Fischer
By Regis Wheeler
By JasonB
By AMK
Tv model 55UJ630V-TA
Sw version 06.10.50
Maciej
Hi, I have a problem with my LG 49UJ634V. It has installed software v. 06.00.20 (the latest one), and I have issue with WiFi connection.
I've checked with different routers and modems, but the situation is the same. When I am connected to WiFi the internet connection is very slow, and I cannot do anything in any of apps. The streaming is too slow to watch something. Only the solution is to plug LAN cable, but unfortunately it is on the opposite site of the room.
Do you know what could be the reason? How I can solve the issue?
