Hello, I would like to disable "Pointer Mode" for my app on LG TV.
My app doesn't currently support pointer mode so it runs into issues when there are users who inadvertently use the cursor. Is it possible to disable?
In the documentation, I've only found cursorStateChange, which is an event when the cursor appears or disappears, but nothing to actually disable cursor mode.
Thanks in advance.
    • By mycop
      Greetings.
    • By u84six
    • By StanJ
      I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
      On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
      I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off,  HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
      Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
      Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes).  It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
    • By Speedemon
      I have a UK6300 LG TV. It has always worked faultlessly. However it now will not show the pointer unless I restart it and then it only there of only for 20 seconds and then it is gone. The LAN cable notification constantly disconnects and reconnects. The Web Browser no longer opens on my selected page. The Software version is the latest and when I tried to manually update the software in case the auto update got corrupted it will not recognize the USB drive as having the software on it. The software browser version is 05.50.15.
      Any ideas what to do. I have two other LG TV's and all work perfectly.
    • By duckie133
      VERY ANNOYING!!!!!!!!!!
