Uk tv doesn’t show uae as a country
I shipped my lg tv from the Uk to the Uae and there is no option to pick uae as location- it is not on the country list.
I am now not able to install local apps like osn and Disney plus (uae version) so the only thing that works is Netflix.
I tried selecting other as the country location but then even Netflix disappeared so have had to change back to Uk.
how can I change the location to uae as this where I am not using the tv? It’s really annoying me as I have no idea why uae is not an option on the country list.
any help is really appreciated
thanks
    • By qix70
      Hi, could you help me please?
      My code now is 541641992
    • By Sqwazy
    • By Mohammad1403
      Hello there,
      Is it possible to turn off search on the home screen, or filter results to show only apps? Ideally, I'd like to limit content to be appropriate for kids.
    • By SergeNault
      Hello all, quick question,
      I have an LG Smart TV, with the latest firmware ( 04.50.56), that is connected to a PVR ( Cisco).  That PVR, via a cable company called Videotron,  has about 50 of exercise videos of 20 minutes recorded over that past years.  I wish to move away from my existing TV provider, but before doing so, I'm trying to figure out how to export the videos into an external drive ( USB, cloud) , so that I can re-use them. Some people have suggested to remove the hard drive from the PVR and export to a USB, but those files are encrypted.  So outside of using my Iphone and actually record the shows, is there a better quality way of doiing it?  I'm thinking some sort of app, that the TV can download, and then record to a USB drive for example.  Thanks for sharing any positive outcome.
      Serge
    • By Cash
      Have LG OLED 55B36LB bought in 2023 in UK.
      Trying to change area option from 3122 (EU-UK) to 4816 (AJ-India) using a service remote.
      It does not update or change.
      any help for guidance will appreciated.
