Switch From App to Antenna TV program via remote control voice no longer working properly
By Venkata
Hello Team,
By Peter_T
By RJ Fischer
By wallyricks
Paul Griffith
When I try to go to a TV programme via the remote control voice option, the TV tries to look up the channel on the app I'm on, instead of going straight to the TV channel on the antenna. This used to work without any problems up until a couple of days ago. Any help appreciated.
