PreCentral: Astraware TouchPad Totalizer tops 5000, OddBlob and Astraware Casino en route
Folks, it happened:
tracker of TouchPad game sales finally topped 5,000 sales, the top level for Astraware's we'll-make-these-if-you-buy-enough-of-those deal. Granted, 5,000 isn't a huge number for Astraware; they likely sell more than that in a day on iOS or Android - when you're on a platform that , five thousand is a drop in the bucket for a firm like Astraware.
The progress up the Totalizer totem pole has seen the release of to test the waters, with and following as further sales targets fell. But things hit a hitch around the 3500 mark, where one would find the popular Astraware game OddBlob. Sudoku and Solitaire saw releases shortly after hitting the sales targets, but OddBlob has not hit the TouchPad App Catalog yet despite it having been quite some time since the sales target was hit.
Asked about this seeming oversight on the Twitters, Astraware admitted that the process of transferring OddBlob to the TouchPad "has taken longer than expected", so you should expect Astraware Casino to hit first. That said, OddBlob and Casino are both popular games and we wouldn't be surprised to see them sell a few thousand copies on the TouchPad eventually.
It's a testament to Astraware that they're willing to put the work into using the to bring their apps to the TouchPad. As the delay with OddBlob has shown, it's not always , but we're happen to see Astraware making the effort even for just the few thousand sales that the TouchPad user community can bring. Sometimes it's not about the money, though we doubt Astraware would be doing this if they weren't at least breaking even - that's why they set up the Totalizer in the first place, so that we could see ourselves what it would take to make it worthwhile in Astraware's eyes.
a2t.imgWxWACB4aPTI
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
      Company Named in Globally Respected Corporate
      Sustainability Index for Its Strong Commitment to ESG Management
      SEOUL, Dec. 13, 2022 — LG Electronics (LG) has earned a place in the Dow Jones Sustainability World Index (DJSI World) for the eleventh consecutive year, illustrating the company’s ongoing leadership in responsible ESG management.
      The DJSI World lists only the top 10 percent of over 2,500 global companies in terms of corporate sustainability, evaluating each organization based on in-depth analyses of their environmental, social and governance practices. Updated annually, the DJSI World is widely viewed by investors, governments and other key stakeholders around the globe, as a reliable indicator of corporates’ ESG commitment.
      LG scored well in all three areas of ESG management in this year’s Index. Receiving high marks for its various environmentally-focused initiatives, the company is actively reducing greenhouse gas emissions and water usage while also increasing recycling rates, converting to renewable energy sources and making steady progress toward its goal of achieving carbon neutrality by 2030. LG reduced the total amount of direct and indirect greenhouse gas emissions from its domestic and overseas sites by 40 percent last year (compared to 2017 levels).
      In terms of the social criteria measured, LG garnered a favorable assessment from the DJSI World for its strong efforts in supply chain management, workplace diversity and for the creation of an inclusive culture. The company also earned a positive evaluation for implementing transparent and responsible governance practices, including the disclosure of its Board Skills Matrix (BSM), establishment of the board guidelines on independence, expertise and diversity.
      Dedicated to realizing a more inclusive society through providing products that are truly accessible, in Korea, LG recently introduced cost-free braille stickers to enable people with visual impairments to more conveniently operate appliances. The company has also shown its commitment to meeting the highest global standards with the acquisition of ISO37301 certification from the British Standards Institution (BSI). Developed by the International Organization for Standardization (ISO), ISO37301 is an internationally-recognized standard for assessing whether a company’s compliance management policies and risk management systems conform to global standards.
      In addition to being listed in the DJSI World for 11 years in a row, LG has made the DJSI Asia Pacific Index for 13 consecutive years, and the DJSI Korea Index for 14 consecutive years. Assessing the same criteria as the DJSI World, the Asia Pacific Index includes the top 20 percent of the top 600 companies in the Asia-Pacific region, while the DJSI Korea Index recognizes the top 30 percent of the top 200 companies based in South Korea.
      Furthermore, LG has been awarded Platinum status for the second straight year by independent, globally-trusted provider of business sustainability ratings, EcoVadis – putting LG in the top one percent of all companies in terms of sustainability initiatives. And for the last two years, LG has been given an ‘A’ grade by global investment research firm, Morgan Stanley Capital International (MSCI).
      LG’s ESG management practices and goals, including the mid- to long-term strategic tasks the company established earlier this year, are clearly laid out in its Better Life Plan 2030. The plan embodies LG’s commitment to realizing a more inclusive and diverse society by embracing differences and forming close-knit circles of alliance with company employees, corporate partners and stakeholders.
      “We will continue to do everything we can to realize our vision for a more sustainable future, leveraging our experience, innovative technologies and global presence to help make life better for all,” said Hong Sung-min, head of LG’s ESG department.
    • By ajmboy
    • By Alex
