Buffering problem .... LG TV (55UM7610PLB)
By PVD
By hollean
By AJO
By BozaB
I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
By DeJaVu
Baffledron
Ongoing problem!!
About a month ago I switched from BT to Vodafone FTTP (Fibre) broadband (100Mbps)
Since then I've had buffering on my LG TV (55UM7610PLB). This is connected to the router by ethernet cable.
My first thoughts were to do with the internet connection, I checked and tested everything. Vodafone have also checked everything and Openreach have replaced the ONT. Still got the problem though.
So, I've turned to the TV. The LG chat and phone help were pretty low level and not at all helpful.
Google turned up a possible solution which involved resetting the location services and removing it's automatic status. This sort of worked. Watching UHD Frozen Planet 2 was bufferless. But the next day, watching ITV hub was worse than ever.
You would have thought with an 100Mbps connection it would all work so well....but it doesn't.
Is it the TV?
Is there a fix?
Any ideas much appreciated.
Ron
